Plugging Off Fuel Return Line
Old Aug 20, 2009 | 12:36 PM
DB Admin's Avatar
Banned
Default Plugging Off Fuel Return Line
Used to be a way to blow some major smoke , anyone ever tried it on a cummins?
Old Aug 20, 2009 | 01:28 PM
mysterync's Avatar
On what year truck? It returns for a reason DM
Old Aug 20, 2009 | 01:52 PM
2500HeavyDuty's Avatar
yeah, if it dont return or regulate pressure/fuel stuff starts to break
Old Aug 20, 2009 | 11:24 PM
DB Admin's Avatar
Banned
Oh now i know for a "fact" that a Dime will fit right in there then you hook the line back up and now your getting 100% fuel
This was on an old toyota diesel pickup
Tore the clutch out but it smoked like a freight train and ran like a bat outta hell
Old Aug 20, 2009 | 11:28 PM
DB Admin's Avatar
Banned
Do they have After market Overflow Valves for the P7100 ?
Doesnt the Over Flow valve regulate the fuel into the return manifold and back to the tank?
i think there may be a FREE mod that were not using to its full potential ?
Even if we dont block it 100% maybe we can restrict it ?
Old Aug 20, 2009 | 11:31 PM
mysterync's Avatar
I was just being a smart *** ....after all it is you DM ...but that is pretty cool!
It really regulates right to the tank. And opens lower than the actual pump psi. The return manifold goes back to the fuel filter housing and enters with low pressure fuel.
But , the p7100 seems pretty happy with 25 and opening valve at 22. I know there's some aftermarket ones but not much fuss was made.....the pumps seem to do fine without. Seem's like some of the newer ones are higher than 22
DB Admin's Avatar
Banned
I understand the VP44 is Fuel cooled so that wouldnt be a good idea , But with the P7100 why waste the fuel that the Liftpump is pumping Shove it into the cylinders ?
Just thinking out loud here , Whats your thoughts ?
Old Aug 20, 2009 | 11:35 PM
mysterync's Avatar
Well....While the P7100 is oiled and oil cooled, the fuel also helps cool the pump , hence the reason it opens lower than pump pressure. Some folks push the pressure way up and modify the overflow to pulling trucks and such. I'm not very smart on this area....someone find hammer! He'll explain better!
Old Aug 20, 2009 | 11:39 PM
DB Admin's Avatar
Banned
Seems like a complete waste of resources to regulate the amount of fuel going into the cylinders with a return line , the technology is there for the lift pump to just send what fuel is needed . the pumps can be cooled by other means
Old Aug 20, 2009 | 11:55 PM
mysterync's Avatar
Another thing, Whats not used by the injectors is sent back to the filter housing....At some point unused fuel has to go back
