more power
Old Aug 19, 2009 | 04:12 PM
dodge rodder's Avatar
Default more power
what would you guys prefer as far a more powerful module than Quad ZXT+ that would not break the bank of $500. this will be my last upgrade for a while. i want to go as big as i can for the money. How good is a Granatelli Big-G Diesel Power Modules they claming 120 hp - 240qt
Old Aug 19, 2009 | 04:14 PM
I run the Quadzilla Adrenaline and I love it. Ive also ran the Edge Comp Box. If your looking for all out Power get the Adrenaline. If your looking for Easy to Use, smooth and still strong get the Edge Comp or Edge Juice with Attitude.
Old Aug 19, 2009 | 04:25 PM
i have been looking at the Adrenaline,but my brother has a super chips 3588 i think and we stacked it and it sucked *** sounded like it was going to blow the head off , so im not going that route. I WANT POWER
just a quick question - what is fuel presser need to be at full trottle i have about 7-9lb it is scaring me do i need a bigger pump
Last edited by dodge rodder; Aug 19, 2009 at 04:25 PM. Reason: Automerged Doublepost
Old Aug 19, 2009 | 05:20 PM
turbo20psi's Avatar
I would get a bigger pump if you are adding a Quadzilla Adrenaline or a Edge comp box,7 to 9 psi I would be scared to.I have 15 to 20 psi on both trucks at idle to WOT.Seems to keep the VP-44 goddess very happy.
Old Aug 19, 2009 | 05:45 PM
BlackDodge's Avatar
What did you stack the super chip with?
Old Aug 19, 2009 | 05:47 PM
Jet A Fuel's Avatar
I read a post from Whitmore and under dyno conditions ,that 5 Psi is the minumum that the VP44 requires to produce max power, That is 5psi at WOT
Old Aug 19, 2009 | 05:49 PM
mysterync's Avatar
It takes atleast 12 lbs to produce 839 RWHP....If you drop below 12 on a VP truck you'll start loosing power left and right, Your also putting your pump in danger!
Old Aug 20, 2009 | 08:55 AM
quadzilla zxt+ with 2000 tune
will the Raptor Pump 150gph keep up enough presser for my setup
Last edited by dodge rodder; Aug 20, 2009 at 08:55 AM. Reason: Automerged Doublepost
Old Aug 20, 2009 | 10:47 AM
mysterync's Avatar
Yes, your 150 is more than adequate to produce 600+ RWHP
Old Aug 20, 2009 | 11:18 AM
right now i have a cheap BD lift pump
