2001 wont start
Old Aug 19, 2009 | 11:59 AM
sde67's Avatar
Default 2001 wont start
2001 dodge diesel starts fine when cold but when engine gets hot will only start with shot of eather once started runs fine but if you turn it off have to open hood spray eather or wait tell it cools down help
Old Aug 19, 2009 | 12:13 PM
Jonny's Avatar
fuel pressure? modifications to your truck?
Old Aug 19, 2009 | 12:49 PM
sde67's Avatar
fuel presure is 17 psi diablo power puck
Old Aug 19, 2009 | 12:55 PM
stkdram55's Avatar
do our starters have an over-crank protection sensor on them...i know some of the big rig starters have them...basically it senses how hot the starter gets and opens a circuit so it wont do crank...so if it is faulty then it will sense the heat from engine and open the circuit and you'll be in a no crank situation...
Old Aug 20, 2009 | 09:05 AM
sde67's Avatar
found problem when changing the fuel pump and filter a pice of something got into the relief valve and pluged up the little hole on the banjo bolt that is infront of the the spot where the ball seats blew it out with air put it in works great starts every time
Old Aug 20, 2009 | 09:59 AM
DIESELDENT's Avatar
Its a verry good think that didnt get sucked into the VP, glad your back up and running
tntmechanic
May 18, 2016 04:59 AM
tim12valve
Apr 27, 2015 11:42 AM
ronstop
Feb 26, 2015 09:48 AM
rschriek
Jan 26, 2015 07:30 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
