Whats my 6.0 problem?
Old Aug 19, 2009 | 11:40 AM
snakerupa's Avatar
Default Whats my 6.0 problem?
04 F350 6.0 FX4. When I start it up in the morn. it blows white smoke and seems to have no power for about 1 mile. Then it finally coughs and runs fine. I don't seem to be loosing coolant but do smell a slight antifreeze odor on occassion. Has 129k on it. I bought it with 90k and not sure what has been done previouse to my owning it. I do know it is stock. Im thinking maybe bad glowplugs, injectors, or a leaking egr cooler. i am considering installing an egr cooler bypass as we have no emmission testing here. Any suggestions?
Old Aug 19, 2009 | 05:30 PM
kslb7's Avatar
It could be signs of a bad EGR or bad fuel. Has this been happening after multiple refills?
Old Aug 19, 2009 | 05:50 PM
mysterync's Avatar
Have you done any maintenance to the truck ? The 6.0 Craves the attention of its owner
Old Aug 19, 2009 | 08:31 PM
04redstroker's Avatar
change the oil and all the filters and see if that helps. Sounds like an injector or two is gettin weak. My truck did that when its cold out until i got the new heat induction flash.
Old Aug 19, 2009 | 08:39 PM
mysterync's Avatar
you might try some bg CPR at your next oil change. If you need some we have it in stock!!
Old Aug 20, 2009 | 08:34 AM
snakerupa's Avatar
I work at an auto shop(metric) so I am constantly changing fluids and filters on this beast. It does not happen only after refills but after every cool down and start up cycle. In all weather conditions. I do not tow or really haul anything substantial and the coolant appears clean. There is no staining of the coolant tank so I am assuming the coolant has been maintained prior to my owning. Any thoughts on egr cooler bypass kits? While I'm in there I may replace glowplugs and injectors also.
Old Aug 20, 2009 | 07:53 PM
Big Angry Hillbilly's Avatar
Sounds to me like you got some ratty injectors or a weak FICM. Do you have access to a scan tool? You need to monitor the PID data regarding the FICM voltages.
Assume nothing regarding maintenance. Change the coolant. PM me the VIN and I will get you a warranty history on it. 'In there' doing an EGR delete, is not really 'In there' to change injectors, if you didn't already know. Injectors for these trucks are also quite expensive.
If the FICM power is alright, I would suggest getting the latest inductive heating flash installed and monitoring it from there.
Hope this helps.
burndiesel
10
Feb 7, 2023 01:15 AM
Tylerbuckley
9
Sep 21, 2015 08:24 PM
ish1521
Aug 26, 2015 08:42 PM
scubasteve12
Mar 29, 2015 09:39 PM
njnick
Nov 17, 2014 01:13 PM
