power steering help!
Old Aug 18, 2009 | 09:29 PM
c0zgrove's Avatar
Default power steering help!
hey guys i just replaced my steering gear and now i can barley turn the wheel at all and my pump is whining, my brakes are acting up too you guys have any ideas? can the lines be backwards or are they specific to each hole really need some help
Old Aug 18, 2009 | 09:35 PM
2500HeavyDuty's Avatar
is there air in the powersteering lines?
Old Aug 19, 2009 | 12:07 AM
tower_ofpower's Avatar
sounds like air... jack the front end of the truck and go from stop to stop with the engine off atleast... 20 times. check the fluid and start it up... it may still whine abit but symptoms should be dramatically better... drive it around. if it's air it'll stop with normal driving
Old Aug 19, 2009 | 05:14 AM
c0zgrove's Avatar
no air in the lines, the lines are getting really really hot though
Old Aug 19, 2009 | 01:00 PM
see if the lines do interhcange... i dont think they do but the lines on the steering box shouldn't effect the lines that feed the hydroboost... may have washed a piece of dirt through the pump. if the relief valve is stuck open you won't be able to turn the wheel (doesn't build pressure) but a whine is typical of air; it's the only reason i know of that makes PS pumps whine.
Old Aug 19, 2009 | 02:57 PM
c0zgrove's Avatar
ill check it out tonight when i get home
i know at idle it seems to pump alittle the steering is tight but i can turn it with one hand now when i do like a high idle it gets harder to turn where is this relif valve atnd how do i check it
Old Aug 19, 2009 | 07:03 PM
it's built into the pump; on the high pressure side right before it goes into the hose... usually if you crank the wheel all the way to one side or the other and bottom it out against a stop it'll peak pump pressures and you should hear a hiss... the hiss is from the power steering fluid being bypassed (the pressure relief will be unseated in this position, but seated in normal operation) if your having problems steering it at higher speeds it sounds like the pump is having a cavitation problem... it may be getting air locked
Old Aug 20, 2009 | 05:47 AM
c0zgrove's Avatar
well i figured it out it was the wong steering box got another put it on and all is good now thanks for the help guys
Antwhite19
Aug 23, 2015 06:07 AM
ramrunner01
Jun 1, 2015 12:10 AM
krg3590
Mar 15, 2015 08:57 AM
1MooseheadPlease
Oct 13, 2014 05:33 AM
sweetv8s10
Oct 7, 2014 09:47 PM
