star screw
Old Aug 18, 2009 | 05:23 PM
mn97cummins's Avatar
Default star screw
i was wondering where the star screw should be in the whole when i take the bolt out ( stock position)
Old Aug 18, 2009 | 05:26 PM
captain_stabbin's Avatar
i would think in the middle, maybe i am wrong
Old Aug 18, 2009 | 05:42 PM
mysterync's Avatar
Stock posistion is set diffrently from pump to pump a few turns but IIRC it's a little looser than half way. It's really a prefrence issue in regards to how you want your truck to drive. If your fueling big, You'll want it a little bit looser (the spring) so you dont get to much fuel while trying to spool!
Old Aug 18, 2009 | 05:46 PM
Hammer's Avatar
Star wheel as stated should be as you want it for low end spool up.
Some like it a tad tighter to help control low end smoke,some like it alot looser.
It also determines what spring is being utilized in the housing as to the setting.
Old Aug 18, 2009 | 06:17 PM
i just bought the truck and it is all the way to the front of the hole does it go more and will it hurt anything if i dont have gauges yet or anything with my tranny(auto)
Old Aug 18, 2009 | 07:38 PM
xzaq103's Avatar
FormerVendor
The only thing it will hurt is our milage. With a stock plate and spring your not going to be doing much.
Old Aug 25, 2009 | 09:48 PM
lodal cummins's Avatar
i thought just switching the washers and grinding a bit off the lever arm allowed for full rack travel. should you replace the spring as well? any info would be helpful!!!!1
Old Aug 26, 2009 | 05:45 PM
12vcummins96's Avatar
it is all about how you like it
Texasboy
5.9L Rotary Performance
Sep 19, 2016 12:06 PM
Fred427
Jun 29, 2015 09:43 AM
Mr. Walkway
Dec 11, 2014 10:28 AM
NiNjAassasin545
Dec 2, 2014 11:40 PM
jmerriman17
Nov 21, 2014 04:38 PM
