missing!!!
Old Aug 18, 2009 | 03:58 PM
captain_stabbin's Avatar
Default missing!!!
i was driving my truck the other night an when i came to the light i noticed it started missing so i continued to drive it home an i kinda got on it, an it seemed to runn fine, so i changed injectors an still have missing problem sounds like a bad piston but i also heard from several people that it is prolly a fuel problem, could pump be goin out, or is that a bad delivery valve? thanks
josh
Old Aug 18, 2009 | 04:19 PM
xzaq103's Avatar
FormerVendor
Did you try cracking each injector line at a time on the injector and listin to see if the engine noise changes? Might help you track down the bad cylender. Does it do it cold or only when hot or both?
Old Aug 18, 2009 | 05:35 PM
yes checked all injector lines an it does it hot an cold
anyone?
Last edited by captain_stabbin; Aug 18, 2009 at 05:35 PM. Reason: Automerged Doublepost
Old Aug 18, 2009 | 05:48 PM
Hammer's Avatar
Could be anything from air getting into the fuel system to a sticky barrel and plunger.Since you say you changed the injectors out then they should be eliminated for the issue.I'd start first checking the fuel system looking for places where air can get into it and go from there........Andy
Old Aug 18, 2009 | 05:55 PM
Lil Dog's Avatar
Fuel lines would be a start for some sort of leak, like Hammer said. I would then pull the filter and see if there is anything in there abnormal. After that its checking pressures to the IP from the LP. A good dose of injector cleaner might help as well. I know I had a slight miss when on of the injector return lines were leaking.
Old Aug 19, 2009 | 10:30 AM
big_dog37074's Avatar
I had sort of the same problem. Its happened to me in the winter thought the truck was geling up. Come to find out it was sucking air in at the fuel heater. So I bypassed it.
Old Aug 19, 2009 | 09:35 PM
i changed fuel filter, still missin, only thing i can think of is maybe the pump is bad
Old Sep 4, 2009 | 08:38 PM
12valvefarmboy's Avatar
man mine is doin the same thing. I replaced injectors, injection pump, got an air dog lift pump, thought my lift pump might be bad and it still does it. i have cleaned filters, ran fuel treatment nothin has cleared it up.
Old Sep 23, 2009 | 08:31 PM
12 valve avalanche's Avatar
did anybody find a solution to this missing problem? i have a miss in the 3rd cylinder on my 95. crack the injector line the miss goes away. excess fuel bleeding out between exhaust manifol and head. not the injectors. not the valves. possibly pump? need help? thanks
also has excessive blow by...any suggestions?
Last edited by 12 valve avalanche; Sep 23, 2009 at 08:31 PM. Reason: Automerged Doublepost
Old Sep 24, 2009 | 07:17 PM
Cowboy_Customs's Avatar
Anyone? Mine does the same exact thing!
