not running right
Old Aug 18, 2009 | 12:52 PM
luke46's Avatar
Default not running right
So I installed my airdog 150 this weekend and my bhaf still building a heat shield. And the truck when I get off the highway still has a miss It really ran like crap the other day after I got done towing a backhoe. Till I let it idle for a bit then it clears up. It runs way smoother and seems to be quieter now. No big difference on power I can tell. It was doing the same thing before the install. I just bump my rpm up to about 950 with the torx screw and it almost always quits so I am leaving it there for now.
Old Aug 19, 2009 | 02:15 AM
toy4xchris's Avatar
I am not too knowledgeable with the 24v's but have you checked for fuel pressures? might be leaking off somewhere.
Old Aug 19, 2009 | 03:09 AM
Jonny's Avatar
changed your fuel filter anytime you can remember?
Old Aug 19, 2009 | 06:36 AM
GOOD OL' BOY's Avatar
I'd start with changin your fuel filter and while ur under the hoocheck your fuel lines and injectors for leaks.
Old Aug 19, 2009 | 12:35 PM
luke46's Avatar
brand new fuel filters and fuel lines good pressure too. Can't see any leaks to the injectors do I need to pull my valve cover I am going to adjust them shortly anyway.
Old Aug 23, 2009 | 09:48 PM
oudive's Avatar
I would recheck the injector lines. I thought I had tighten one back up real good after priming the system. Turns out it started good and it ran fine until I started getting on it, then it started the missing. Check those or the the ones leading into the VP44, whichever one you might have used to bleed the system after the AD install.
Old Aug 23, 2009 | 10:42 PM
luke46's Avatar
ok I'll recheck everything when I get my kid out of the hospital got real sick and had to get flown up state so no diesel work for now got to get him better than my truck.
Old Aug 24, 2009 | 06:38 PM
oudive's Avatar
man, sorry to hear that. I hope your child gets feeling better real soon.
ssmith.77
Nov 25, 2018 06:56 AM
ROCKITV8
Jun 17, 2015 08:38 AM
carid
Diesel Bombers Sponsors
Apr 6, 2015 08:43 AM
CumminsAtYa
Mar 17, 2015 09:23 AM
carid
Jan 12, 2015 04:32 AM
