cheapest & most effective power combo?
Old Aug 17, 2009 | 07:45 PM
78malibuboy's Avatar
Default cheapest & most effective power combo?
I just bought an 05 f350 harley davidson, and im curious what is the best combination for added power that you guys know of? also what is your opinion on the banks intercooler & high ram intake? thanks!
Old Aug 17, 2009 | 10:03 PM
crewed powerstroke's Avatar
Everyone has told me that you need an air intake , a SCT tuner , and a 4" exhaust ; then you will have a 400 H.P. 6.0 l rocket . Good Luck . Also welcome to DB.
Old Aug 17, 2009 | 11:15 PM
Start off with some Gauges to Keep your engine safe. Add a SCT Xcal3 programmer, 4" Exhaust and a good AFE intake. You will gain better performance and improved fuel economy as long as you can keep your foot out of the throttle.
Luke
Old Aug 17, 2009 | 11:49 PM
Superstroker10's Avatar
sct custom tuning (not too excessive), zoodad mod, intake and exhaust
Old Aug 18, 2009 | 08:55 PM
Big Angry Hillbilly's Avatar
Malibu, eh?
I have a 79. Ladder bar car. Small block on spray.
Building a BIG inch small block with all real good Lunati innards and Airflow 235CC heads. Should rock out about 800hp on the motor. (Gonna almost be a diesel with the compression ratio I'm running.)
Old Aug 18, 2009 | 09:39 PM
04redstroker's Avatar
Sct w/ custom tunes, exhaust, and gauges. The factory intake on the 6.0 is good till around 500HP. There is no real performance or milage gain with an A/M intake. I run one but the only way you can tell its there is turbo noise. The zoodad, havent done it yet though. Studs and an egr delete should be on the list at some point. im still runnin the TTY head bolts
May 10, 2015 10:57 PM
explorer197143
Dec 28, 2014 01:14 PM
