Need to remove washer fluid bottle...
Old Aug 17, 2009 | 05:24 PM
OverPressured's Avatar
Default Need to remove washer fluid bottle...
I need to take the washer bottle out to get the radiator shroud out so I can remove my radiator.. Any trick to doing this? Is there any bolts? I cant see any bolts, and it looks like it should slide up and come right off. But its not moving up more than 1/2 in then it stops. I dont want to break it but it needs to come out since its blocking bolts to my shroud. My vision isnt too great today my contacts are messed up, but help me out please is there something im missing? Its a 98 2500 12v
Old Aug 17, 2009 | 05:27 PM
Uncle Bubba's Avatar
should come up that half inch and then pull lose if i remember right. It just sits in those notches.
Old Aug 17, 2009 | 05:56 PM
Thats what I thought.. But its not coming out. Im going to try again once i get back from picking a few things up in town..
Old Aug 17, 2009 | 06:16 PM
I know I had to use a screwdriver slipped down behind it to pry it out of the slots on my truck.
Old Aug 17, 2009 | 11:02 PM
scrappy's Avatar
there is a catch on the backside of the bottle that catches on a hole in the shroud. stick a long screwdriver between the 2 to push the catch away from the shroud and then pull up.
Old Aug 19, 2009 | 03:36 AM
wildbill's Avatar
*wildbill moved
Old Aug 21, 2009 | 11:42 AM
ratcity's Avatar
I had a hard time taking my water fluid and radiator fluid bottles out the first time. All they do is slide out. Push in on the bottle and pull up. While you are pushing up shake and twist the bottle. It will come out. After you get then out the first time they will go in and come out easy.
Old Aug 21, 2009 | 03:01 PM
06 DIESEL's Avatar
Like said above there is a retainer spot that you have to pull the bottle over. When I took one off last I used the screwdriver method like mentioned above.
Old Aug 22, 2009 | 12:22 AM
12valvetater's Avatar
there are also to little buttons on the bottle that fit it holes on the shroud you have to pull up and push out to unhook them sometimes. once in awhile they get hung up and it can be a little bit of a pain to get the bottle out
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
DieselDan_5.9
Jul 30, 2015 07:05 AM
GasItOut
35
Jul 22, 2015 01:11 PM
01cummins4ever
Dec 28, 2014 07:43 PM
