Transfer Sled Pulling Diesel Discussions of Transfer Sled Pulling , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
need some newbie help
Old Aug 17, 2009 | 03:22 PM
welderboy250's Avatar
Default need some newbie help
Ive pulled farm tractors for a long time. nothin like pullin a truck. i need some help. as for the truck, 95 Dodge auto. got a big air filter, no silencer ring, no metering plate, adjusted afc, increased high idle rpm. still stock turbo but it does make 35psi. the converter is a little weak i think but i wired in a manual lock switch and thats when i found out the converter wont lock until the transmission has shifted into third gear(which in my case is direct). even in low range thats kinda fast with 3.54 rears. so anyhow i need some advice from yall whove been doin this for a while. is second gear where i gotta be? it seems slow. lets the engine rev almost to the limit. also it doesnt make a lot of smoke. i thought there would be a lot more with the metering plate out. anyhow hope someone can help. thanks
Old Aug 17, 2009 | 03:53 PM
sidekick's Avatar
i run mine in od and tow haul normally it will go into od get all the tire speed posible with out letting the rpms drop to low hope it helps you
Rescuedu
Aug 26, 2015 05:38 PM
AmberAlert69
Aug 23, 2015 09:02 AM
Mopar92
Jan 24, 2015 08:54 PM
ilovetacos
Dec 10, 2014 12:55 PM
plow_this
Nov 16, 2014 11:40 PM
