Long Cranking Before Starts
Old Aug 16, 2009 | 09:19 PM
Gibby's Avatar
Default Long Cranking Before Starts
About 3 weeks ago i started having a problem with my truck not starting! it will start after about 10 seconds or so and it really pulls the batteries down. Sometimes i dont have a problem with it starting! it will start up just fine but for the most part of the time it takes forever. When i turn the key i hear the pump hum for a sec and stop! then turn the key and it doesnt start. fuel pump kicks in and runs it cycle for about 10 seconds and normaly it cranks after that. I have just installed the 150 air dog with half inch lines, and a new bosch vp44 about 4 months ago! i was running the quadzilla aderaline! it messed up about 2 weeks ago! it would drop the settings to 00 and freeze the pyro read out! once i cut the truck off it wouldnt start back so i unpluged the chip and it finally cranked? Sent the chip to quadzilla and havent heard back from them! any ideas? is there a check valve, or something on the vp44 that is stuck or something electronic! please help me
Old Aug 16, 2009 | 10:02 PM
01trailerpuller's Avatar
Do you have a fuel pressure gauge? When was the last time you ran some injector cleaner through it?
Old Aug 16, 2009 | 10:45 PM
Gibby's Avatar
yea my fuel pressure gauge has been acting weird! it takes a while 2 build up to 20 psi! but its been that way for like 3 months way b4 this problem started! but while the truck runs it holds bout 19 psi! idk im stumped! and no injector cleaner! should i try that and what kind?
Old Aug 16, 2009 | 10:53 PM
Lucus is one of the best injector cleaners on the market. If your not getting a good mist it would be hard to start. Do you smoke while trying to start? Also is it at 15+psi before you try to starting it?
Old Aug 17, 2009 | 05:23 AM
Jonny's Avatar
try changing your fuel filter! check your fuel fittings! why are we shouting?!!?
Old Aug 17, 2009 | 11:15 AM
Kinda sounds like the lift pump
Old Aug 17, 2009 | 09:58 PM
Gibby's Avatar
well i think its something 2 do with the acuator for my fuel pressure gauge! i opened the cap then closed it and it started rite up several times! then i let it sit and it took mayb 3 seconds so it seems to get better but whys is still taking long! will it hurt the vp44?
Old Aug 17, 2009 | 10:06 PM
mysterync's Avatar
Lucas is actully one of the lower quality injector cleaners. Theres actully a complete list of additives, It being high in acohol content (IIRC) and low in lubricity puts it pretty low on the list. Most likely after your description of the problem, you're in the need of a fuel filter for starters. Secondly, Most injector cleaners that you can buy off the shelf would make little to no diffrence in spray pattern. Might also look at connector tube o-rings, injector line leaks or a failing VP-44
15lbs is wanted a few seconds after the first few turns. You dont want 15lbs until after the truck has fired. It CAN create hard starts. Not saying anyones wrong just clearing up some facts! Hope this helps.
Old Aug 20, 2009 | 09:32 PM
Gibby's Avatar
Well i cracked the isolator going to my fuel pressue gauge and seemed like it help! it fires rite up! out of 2 days of on and off its only not started up 4 times out of 20 id say! so how can i get the rest of the air out? jw thanks 4 all the help!
Excursion73
Sep 9, 2015 09:20 PM
torino73
Apr 14, 2015 11:15 PM
dandbmcc
Mar 14, 2015 11:05 PM
weatherby
99-03 7.3L Performance
Nov 5, 2014 10:45 PM
mpenny671
Oct 7, 2014 01:18 AM
