cyl head 93 to 97
Old Aug 16, 2009 | 12:07 PM
97 dodge's Avatar
Default cyl head 93 to 97
I am building a 5.9 cummins from a 93, to put in a 97....does anyone know if the cylinder head will work with the p7100 fuel system? The pistons that are installed are 16.5:1 for a 93....will this combination work for the 97? Any help would be appreciated. The engine is only short block right now. I knew there was a difference on injectors but I'm not sure that this is going to work.
Old Aug 16, 2009 | 01:03 PM
RSWORDS's Avatar
YEs the head will work. You need the timing case, injectors, injector lines and a couple other odds and ends it your putting teh p-pump on the 93 block. All bolt on stuff...
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
spark'd
Feb 7, 2015 02:07 PM
Vmason
Jan 21, 2015 11:33 PM
Adam65
Jan 9, 2015 11:50 PM
Oct 31, 2014 08:10 AM
