yeehaw
Old Aug 14, 2009 | 07:49 PM
cummins95's Avatar
Default yeehaw
finally got the gauges hooked up so i dropped in the 100 plate n wow did that wake the old girl up. pushin about 35 psi n gotta try really hard to get the egt's over 1000. just gotta watch the black smoke in certain areas very pleased. only problem is i cant put it full forward cuz the fuel shutoff solenid wont line up with the afc bolts, any suggestions?
Old Aug 14, 2009 | 10:58 PM
Lil Dog's Avatar
Where is your pyro located? With those temps I am going to guess after the turbo?
The AFC bracket should move if you loosen the lower mounting bolt a bit. May take a little bending, but the AFC doesn't move that far.
Old Aug 15, 2009 | 06:50 AM
cummins95's Avatar
pyro is pre turbo, i only have the plate set about half way forward. i'll try to get everything slid forward so i can really take advantage of it
