prefilter
Old Aug 13, 2009 | 04:42 PM
colt45_usmc's Avatar
Default prefilter
Hey guys hows it going. I am trying to figure out where to find the sediment bowl and screen to clean them out on my 1998 12 valve. im having trouble with it firing and the fuel cutoff silenoid keeps sticking and not letting it fire, do i need to replace or can i repair it?
Old Aug 13, 2009 | 05:43 PM
oglejust's Avatar
the fuel heater bowl? its under the pump, its a round bowl.. u cant miss it
Old Aug 13, 2009 | 06:07 PM
big_dog37074's Avatar
Bypass that fuel heater. you dont need it. It could cause a problem down the road. It did on me I couldnt find out what the hell was wrong. So I by passed it. Solved the problem.
Old Aug 13, 2009 | 07:47 PM
ok i really appreciate it
Old Aug 13, 2009 | 11:39 PM
oglejust's Avatar
how do u bypass it and howd urs give u problems?
Old Aug 14, 2009 | 08:11 AM
Just hook your fuel line coming from the tank straight to the fuel pump. From the factory the fuel comes from the tank into the fuel heater then into the fuel pump or "lift pump". Last winter I keep having a problem. I thought my truck was geling up. Well it wasnt I replaced everything it was still doing the same thing. So I broke the fuel line loose there was so much air in the system I dont even see how it would even start yeah it missed like hell though. So someone told me on here to bypass the fuel heater, and I did. I havent had a problem since.
Old Aug 14, 2009 | 10:11 AM
94cummins12v's Avatar
if you lived somewere it got below 0 i wouldnt suggest doing this
Old Aug 14, 2009 | 10:19 AM
Thats true I forgot to add that.
Old Aug 14, 2009 | 01:03 PM
will1am's Avatar
there is a way to take the feul heater out and still have the fuel go thru the screen fuel bowl.
i am going to do this soon.dont have the link for article....seach for fuel heater and you will find it.I live on the ***** of amercia...i dont think i have to worry about zero degree temps though.I am also thinking i should mod my heater air element or just take it out for more airflow.but from what i have read this may not be worth the time.
Old Aug 14, 2009 | 06:09 PM
oglejust's Avatar
so how did u go from the steel line that goes into the heater to the rubber line that goes to the lift pump? how r they connected to each other?
dont mess w/ taking out the grid heater unless u plan on injecting something thru the intake
