injector
Old Aug 13, 2009 | 02:33 PM
cummins_guy's Avatar
Default injector
OK, I have found that there is two types of injectors for the 1st gen
there is a 6btaa injector designed for the industrial Cummins motor, they are tested at 190/210 hp, i have installed a set in one of my trucks, started the truck with the 6btaa injector, i noticed as soon as I took off, black smoke poured out the back, this is without modifications done to the pump.
Put the originals back in and there was no more smoke, my dyno is screwed up, so I cant give actual readings.I will send off a set to a buddy of mine to get me some specs on these things.
when i look this up in Cummins, it shows my injectors are for a 6bt, then when i look up the other injector it shows for 6BTAA, Cummins wont give me any specs for these.
Old Aug 13, 2009 | 04:47 PM
ltr450's Avatar
i think they are the wrong spray pattern, might be for the boat engines
Old Aug 13, 2009 | 10:38 PM
tower_ofpower's Avatar
if cummins isn't giving you any kind of info it's deffinately not something that is supposed to be on the road... poke around and find out what pistons go with that injector number... there was a guy asking about possible marine cams on the first gen forum... i could build me a boat engine to put in the truck
Old Aug 14, 2009 | 03:09 PM
RSWORDS's Avatar
I'm sure they are larger but the spray pattern being all screwy is half of the smoke. Thats the reason POD's smoke so bad, the pattern is not right.
Old Aug 14, 2009 | 09:28 PM
to my understanding most extrude hone injectors spray crapily anyways...
lowride
Oct 24, 2015 08:50 AM
Dkolanski06
Apr 23, 2015 09:32 AM
2ndcummins1
Mar 9, 2015 10:01 AM
amztroyer
5.9L 24V Performance
Mar 5, 2015 05:02 PM
J_stout
Dec 14, 2014 07:23 PM
