wiring diagram/ fuse box
Old Aug 11, 2009 | 11:14 AM
MMStar923's Avatar
Default wiring diagram/ fuse box
looking for a wiring diagram for an 06 F-350 PSD. lariat if that makes any difference, but i recently bought a GPS thats mounted to the window and want to run the wiring behind the a-pillar and into the dash by the fuse box. ive done this in my dodge by just picking up an extra cigarette lighter from pep boys, but i already had a "ignition hot" wire running through my dash for my amp, i need to find out what wire i can tie into in the f-350 or what fuse to wire into so that i have an ignition hot wire so that when the truck turns on so does the gps and same with turning the truck off. thanks in advance!
Old Aug 11, 2009 | 03:48 PM
mysterync's Avatar
I looked but theres nothing I can reproduce to help you out BUT I would just pop out my cig lighter and tap in to the hot pin on it!
Old Aug 11, 2009 | 05:23 PM
MMStar923's Avatar
none of my cig lighters are ignition hot though, theyre always on, which equals my GPS straying on even if the truck is off. i want it to shut off when i turn the truck off.
Old Aug 11, 2009 | 05:45 PM
mysterync's Avatar
There's 3 Switched spares in the Fuse box that could be tapped with a fuse tap?
Old Aug 11, 2009 | 06:28 PM
MMStar923's Avatar
do you happen to know the #'s of the fuses in the fuse box that i can tap into? or what about the AUX ports with the 4 switches by the trailer brake controller??
Old Aug 11, 2009 | 09:48 PM
conner's Avatar
Ya your uplifters are set up Aux. Or I usually used the wiper fuse
manns999
19
May 3, 2024 01:40 PM
stone9291
Jul 23, 2015 05:13 PM
Rusted Dragon
Feb 27, 2015 09:46 PM
12valve_soot
Nov 12, 2014 10:02 PM
Altonlee
Oct 1, 2014 04:58 PM
