What Fleetguard Number ?
Old Aug 10, 2009 | 08:19 PM
ROCKITV8's Avatar
Default What Fleetguard Number ?
I need to know what number fleetguard filter fits a 2006 5.9 Cummins.
Thanks !
Old Aug 10, 2009 | 08:30 PM
dieseldude03's Avatar
I assume you are talking oil filters:
LF3972 for the standard replacment.
LF16035 for the STRATAPORE.
Old Aug 11, 2009 | 05:24 AM
ROCKITV8's Avatar
Thanks, yes I did mean oil. Whats the difference in the the 2?
Old Aug 11, 2009 | 04:27 PM
Good question. I didn't know either. I got this directy from Cummins:
Most filters look the same on the outside. It's what's inside that counts. Cummins Filtration exclusively designed StrataPore™ synthetic media in our Media Center for optimum performance and longer life. Unlike cellulose and microglass media, StrataPore™ is multi-layered, with an optimum number of layers for the desired level of particle removal.
StrataPore's™ benefits are:
•Strength and durability
•Less compromise of efficiency and life due to multi-layering
•Organic contaminant tolerance
•Lower filter restriction
Stronger and More Durable Filter Media
Our unique meltblown manufacturing process produces layers composed of continuous, high-strength polymeric fiber, which results in a stronger, more durable bond that maintains media strength.
ESI Compatibility
The ability to optimize individual sheets for desired particle-size removal provides StrataPore™ with increased total media filtration efficiency--particularly effective in extended service environments (ESI).
StrataPore™ offers this capability without sacrificing inorganic contaminant removal. With traditional media, trade offs are made between high efficiency and high capacity. StrataPore™ allows customers to extend service intervals without compromise.
Lower Filter Restriction: Higher Performance
Its unique layering capabilities also allow StrataPore™ to provide nearly 50% reduction of filter restriction during cold start. With traditional media, pore size must be reduced, increasing the pressure required to force oil through the media. The smaller range in StrataPore™ media results in more repeatable, controllable filtration performance.
Award Winning Performance
StrataPore™ has been recognized throughout the filtration industry as a superior innovation, including receipt of an award from the American Filtration Society for its technologically advanced design.
Old Aug 11, 2009 | 04:34 PM
The Stratapore has synthetic filter media - just filters better, longer and with more efficiency.
Genos Garage
Genos Garage
Jul 6, 2015 12:35 PM
RatsMC
May 4, 2015 05:25 PM
countryboy040993
10
Nov 16, 2014 08:21 PM
