bad injector vs particulate filter
Old Aug 10, 2009 | 08:01 PM
bowtieBrian's Avatar
Default bad injector vs particulate filter
Ok, gotta question for you gurus out there. I have an 04 3500, has been running good - no drop in milage, but smokes a little bit at idol (white smoke), and there seems to be a lack of pwoer. Took it to a family friend and he informed me that I have two injectors bad. Dropped it off at the dealership this morning (to capitalize on the warranty), and they told me that afte running the battery of diagnostics, there is nothing indicating a bad injector (everything is producing good pressure, no oil in the fuel and vice versa). The dealer asked if I had the particulate filter on the exhaust changed - it has not. Does anyone know if a bad particulate filter will give the same "symptoms" as a bad injector? I have not had any codes come up either. Any ideas will be great!
Old Aug 10, 2009 | 08:06 PM
ltr450's Avatar
particulate filter you mean the cat i will just cut that thing off. as for the injcetors it is not always going to show up on the computer that and injector is bad seen it happen many of times on the big rigs
Old Aug 10, 2009 | 08:13 PM
wildbill's Avatar
Keep an eye on the oil level. If you got two bad injectors, you will notice a change (viscosity, color, and smell).
Old Aug 10, 2009 | 11:03 PM
03dmax's Avatar
I had the same problem with my 2003! Only smoked at idle and once got to driving it would quit. If it keeps up and you want to get it changed under warranty you will need to have diesel fuel in your oil. If this is found then there is no questions asked. Don't let them tell you the smoking could be bad mass air sensor, cause it's not I bought a new one and still did same crap! It is the injectors for sure!!
Old Aug 25, 2009 | 07:10 PM
thanks for all the feed back. after a battery a testing, the dealership concluded it was not a bad injector (they did however, find that the pressure was low and they changed that parameter in the computer). I've checked the oil and the level has not changed, nor does it seem to smell or look any different. I've heard that the wiring harness could be an issue - going to check that next.
gone ropin
17
Dec 3, 2017 06:31 AM
jeffersonl
Nov 15, 2015 07:35 PM
Bob V
Apr 6, 2015 11:02 PM
jeffersonl
Oct 25, 2014 06:46 AM
james2562
Oct 8, 2014 06:14 PM
