PO611 dtc?
Old Aug 10, 2009 | 04:11 PM
4x4DREAMER's Avatar
Default PO611 dtc?
Could someone shed some light on this for me...Please.
Old Aug 10, 2009 | 05:24 PM
scrotom's Avatar
FICM will throw injector codes like that i think. does the truck have a tuner? hopefully someone smarter than me will chime in.
also check for chaffed wires or loose plugs on the ficm. good luck
Old Aug 10, 2009 | 05:34 PM
4x4DREAMER's Avatar
yes, a bulldog pmt tuner....ficm??? trust me no one knows less about these things than me.
Old Aug 10, 2009 | 06:06 PM
scrotom's Avatar
try putting it back to stock and see if it still throws the code. be sure to check for loose or chaffed wires.where are you in nc?
Old Aug 10, 2009 | 06:11 PM
tlevan03's Avatar
mine popped the same code and runs like sh*t, still even on stock. i just pulled the edge box and its going to the dealer tomorrow. what problems are you having?
Old Aug 10, 2009 | 07:16 PM
4x4DREAMER's Avatar
No problems, just throwing this code...I put it back to stock and now it says p1000 incomplete scan of ob2
I live in Lenoir, gamewell district
Last edited by 4x4DREAMER; Aug 10, 2009 at 07:16 PM. Reason: Automerged Doublepost
Old Aug 10, 2009 | 07:41 PM
scrotom's Avatar
keep us posted after dealer
Old Aug 10, 2009 | 09:11 PM
4x4DREAMER's Avatar
Recall data for: 2004 FORD F250 SUPERDUTYNHTSA Campaign Number: 05V270000Manufacturer Campaign Number: 05S34Make: FORDModel: F250 SUPERDUTYYear: 2004Component:
ELECTRICAL SYSTEM:WIRINGManufacturers Involved: FORD MOTOR COMPANYBegin Date Of Manufacturing: 20030929End Date Of Manufacturing: 20040531Recall Type: VPotential Number Of Units Affected: 180104Date Owner Notified By Manufacturer: 20050722Recall Initiator: ODIManufacturer Responsible For Recall: FORD MOTOR COMPANYDate Report Received By ODI: 20050610Date Added To File: 20050610Regulation Part Number: Federal Motor Vehicle Safety Standard Number: Defect Summary:
CERTAIN PICKUP TRUCKS, SPORT UTILITY VEHICLES AND VANS EQUIPPED WITH 6.0L DIESEL ENGINES MAY EXPERIENCE STALLING WITHOUT WARNING WHILE DRIVING AND MAY OR MAY NOT RESTART.Consequence Summary:
SHOULD THE ENGINE STALL, A VEHICLE CRASH COULD OCCUR
I found this and I am going to call tomorrow..
It did not copy all of it but here is the rest...Corrective Action:
DEALERS WILL UPGRADE THE FUEL INJECTION CONTROL MODULE (FICM) WIRE HARNESS OR REPLACED, AND/OR HAVE A NEW INJECTION CONTROL PRESSURE (ICP)) SENSOR CONNECTOR INSTALLED FREE OF CHARGE. THE RECALL BEGAN ON JULY 22, 2005. OWNERS MAY CONTACT FORD AT 1-800-392-3673.
Last edited by 4x4DREAMER; Aug 10, 2009 at 09:11 PM. Reason: Automerged Doublepost
Old Aug 11, 2009 | 04:48 PM
tlevan03's Avatar
took it in this morning and the FICM was causing all the problems. its being replaced under warranty. i only have 3k miles left on the warranty, i guess im glad it happened now. im sure its not cheap
Old Aug 11, 2009 | 06:46 PM
4x4DREAMER's Avatar
glad that working out for you
