sending feul line from spin on to injection pump bolt stripped
Old Aug 9, 2009 | 01:08 PM
will1am's Avatar
Default sending feul line from spin on to injection pump bolt stripped
i think i stripped the the bleed screw on top of the fuel filter(spin on)the one that goes to the injection pump.it is bleeding a bit of fuel from that area.i can order one from dealer but will take a few days.does anybodty know if i can get one from a hardware store. i will get the banjo bolt and the bleed screw if i can find them at a hardware store.i would rather not wait on delivery to dealer.thanks
Old Aug 9, 2009 | 01:43 PM
HAYMAFIA's Avatar
did you check the copper washers. also the washers with rubber coating?
Old Aug 9, 2009 | 03:19 PM
will1am's Avatar
the washer looks ok but i will get another one too.I just cant tighten up the bleed screw.it will get a lil bit tight then loosen again.if anyone knows if i can get the bolt and screw at a hardware store that would be great!
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
letters4and18
Dec 11, 2014 12:03 PM
