delivery valves
Old Aug 8, 2009 | 11:03 PM
hunter's Avatar
Default delivery valves
can someone tell me the difference between 191 dv holders and .090 holdersi no there bigger but as far as performance how are they.
Old Aug 9, 2009 | 12:49 AM
tower_ofpower's Avatar
this is just what i've been told; not saying it is correct. but for the price to hp gain DV upgrades really aren't worth it. unless of course your flowing a good bit of fuel and your trying to squeeze every last bit of HP as you can out of it (which in previous posts i've read you are)
Old Aug 9, 2009 | 03:08 PM
hunter's Avatar
thanksand i think ur rite they are pricy,but im tryin to get to 500 and im not too far awaydo u have any idea hp wise what the gain would be
Old Aug 9, 2009 | 04:01 PM
daveO's Avatar
I've heard the 191s don't do much for power, just make smoke and heat. That being said, Dynomite Diesel sells some DVs that claim 20 more hp than the 191s with less smoke, and lower temps. I'm running these on my truck. I upgraded from stock, so can't say what the difference would be from 191s, but my EGTs stayed about the same, a little more smoke, and my seat-of-the-pants dyno noticed a little more responsiveness down low.
Old Aug 9, 2009 | 04:18 PM
94 12valve's Avatar
with 191's you should be able to hit 500 hp easy ... I honestly think you are a timing bump and some afc tuneing away from 500 hp. do you have the 180 ppump or the 215?
Old Aug 9, 2009 | 08:37 PM
hunter's Avatar
215 pump and yeah im sittin on 16* rite now and i can go to 18* without studs
but how should i tune my afc
Old Aug 9, 2009 | 10:07 PM
i actually did it today with the parents truck... there's an allen head on the top of the AFC (atleast there is on ours) that plug gives you axcess to the star wheel, turn it in and just play with it... it'll effect more of your torque curve than over all top end numbers; once your in full boost the acf doesnt contact the governor linkage so your top numbers wont go up (wont go down either) so i think you'll be much more pleased with the lower end torque associated with a properly tuned AFC to match your top end HP but as most guys will tell you... they just tinker with it there isn't really a "proper adjustment"
Old Aug 10, 2009 | 12:04 PM
94 12valve's Avatar
yep every truck is different you have to play with it till you get it right. and I wouldent go any higher than 16* with out head studs, what gov springs are you running?
Old Aug 10, 2009 | 09:40 PM
hunter's Avatar
im running 3gsk and im looking into a 4gsk and hd valve springs
Old Aug 11, 2009 | 09:08 PM
ibeemike's Avatar
hi i am looking for stock Delivery Valves does any one have a set they might want to get rid cheap? i think i have one going bad.
