1992 7.3 diesel bone stock.
Old Aug 7, 2009 | 11:27 PM
KNUCKLES DEEP's Avatar
Default 1992 7.3 diesel bone stock.
what can i do to my motor? iam already going to turn the fuel up and maybe look at the turbo kits and exhaust. is there anything eles i can do to it,thanks=]
Old Aug 31, 2009 | 03:43 AM
Countryboysfords's Avatar
MAke sure u get a pyro b4 u attempt to turn the pump up
Old Aug 31, 2009 | 11:42 AM
Sycostang67's Avatar
Especially if you plan to do any towing, it's not hard to hit piston melting temps with a load behind you.
Old Sep 2, 2009 | 07:26 PM
blk99's Avatar
unless you want to pull the engine and build it, thats about all you can do... turn the pump up, turbo, exhaust, intake... you can do propane but i dont recommend it...
Old Sep 7, 2009 | 03:53 PM
yeah im not towing anything its gonna be way to big to tow. im am doin 21 inchs and 53' so i wanna do stage 1 injectors turn the pump up and get water methonal injection and get 7'inch aussise stacks,the other thing i wanna do is maybe put a 5.9 cummins in her for the power plant,
Old Sep 7, 2009 | 07:29 PM
DieselCrawler's Avatar
a few guys over at thedieselstop have installed propane and loved it. drops egt, and engine runs smoother
Old Sep 8, 2009 | 03:39 PM
wowo propane on my motor? it wont blow it up? i was told not to do it to my type of motor. ill probaly do water meth be fore i do that but i look into it, thanks for all the info guys! keep it comin! "KNUCKLES DEEP"
Old Sep 8, 2009 | 05:23 PM
they plumb it directly into the intake, have WOT switch, and pressure regulator. i forget the pressure they run but it does work on these.
Old Sep 9, 2009 | 02:33 PM
oh Wot switch? ive never heard of that. well were would they sell it at?
Old Sep 9, 2009 | 08:05 PM
WOT- wide open throttle. normally a micro switch mounted on the throttle linkage that is activated when the pedal is on the floor
