6.5 oil leak
Old Aug 7, 2009 | 04:24 PM
rednekroper05's Avatar
Default 6.5 oil leak
I have a 94 that was leakin oil bad 1gal in 140miles. All i know is it was leaking on to the manfold. i had replaced the passenger side head gasket about 3 months prior.
My question is does this just sound like a head gasket failure?
Old Aug 8, 2009 | 01:46 PM
DieselSlug's Avatar
If you have oil coming out your head gasket something is majorly wrong. Which side of the engine is it leaking on? Could be oil cooler lines...
Old Aug 8, 2009 | 06:14 PM
it is leaking on the drivers side. im not sure were the oil is coming from just know it was leaking on to the driver's side exahust manafold.
Old Aug 9, 2009 | 05:35 PM
Woody35's Avatar
not a head gasket. im thinking you have rotted out oil cooler lines or the connectors broke. it also could be the oil pan gasket. but probably no t that much oil. it could be a combo of the two
Old Aug 9, 2009 | 11:54 PM
Never really messed with that 6.5 that much but where is the oil cooler lines at?
Old Aug 9, 2009 | 11:57 PM
Woody35's Avatar
they run from the tranny to in front of the radiator. they got a hard plastic sleeve on them that you can move a few inches.
Old Aug 10, 2009 | 12:37 AM
not sure but i didnt think the manuals had a oil cooler. Am i wrong on this?
Old Aug 10, 2009 | 12:48 AM
Turbine Doc's Avatar
is it 4x4? if so the orings in the 90 degree oil filter adapter are probably leaking, a very common issue with the 6.5
Old Aug 10, 2009 | 12:51 AM
no its 94 2wd 3500 w/5speed
Old Aug 10, 2009 | 06:55 AM
DieselSlug's Avatar
Gotta be the cooler lines, when replacing them dont get a stock setup again, they will fail quickly, get a set of braided ss lines...
