biggy b will a turbo off of an 04 will fit 95
Old Aug 7, 2009 | 03:51 PM
Biggy B's Avatar
Default biggy b will a turbo off of an 04 will fit 95
can any one tell me if a turbo off of an 04 will fit 95? CUMMINS
Old Aug 7, 2009 | 03:55 PM
kazairl's Avatar
With work. How much time and money do you want to tie up into this?
You would be better off looking for a turbo off a 04.5-07 cummins as they are bigger.
94 12valve's Avatar
yes but it will not be just a bolt on swap
Old Aug 7, 2009 | 04:24 PM
Biggy B's Avatar
c i have this 04 turbo just layn in the shop there isnt anything wrong with it but on my 12v there is alot of side play as well as up and down, wat all has to b done in order to make this one fit?
and wat about the star wheel twards the block,or the fender ? with plate slid all the way to the front
Old Aug 7, 2009 | 04:28 PM
kazairl's Avatar
new down pipe and charge air pipes. Other than that it is fairly easy. Do you have the cast elbow for the turbo? If so you could use the stock 04 down pipe and cut part of it off and use flex tubing to connect it to your exhaust. Or you could buy a hx40 style downpipe without a flange and order a weld on flange that fits the outlet of your turbo.
For the charge air pipe your going to have to get creative. If you like welding you could buy some bent sections of pipe and make your own. Or use boots to clamp the peices together. However you increase your chances of boost leaks/things blowing off.
star wheel towards fender increases amount of boost to get fuel. Less smoke. Towards block increase fueling for a given boost pressure. More smoke.
Old Aug 7, 2009 | 04:54 PM
Biggy B's Avatar
OK , THANKS were is a good place to put the starwheel?its all the way tight now other than smoke wat will b the effects of that adjustment ? im haven a wetawded moment. i know that this is not complicated
Old Aug 7, 2009 | 05:00 PM
kazairl's Avatar
it also effects spoolup on the turbo. The tighter the spring is the slower the truck will be to spool the turbo. Basically it is up to you where you want to put it. If I were you I would start loosening it and drive it. Loosen it some and drive it. Find that happy medium where the truck spools up fairly quick without a bunch of excess smoke. It will take some time and playing around but you will get it eventually.
Old Aug 7, 2009 | 05:21 PM
Biggy B's Avatar
Default biggy b
hey man thanx im going to try that you have been most helpfull
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
GreenDieselF
Oct 20, 2014 02:05 PM
