Clutch Adjustment
Old Aug 7, 2009 | 03:00 PM
DodgeRam2500CTD's Avatar
Default Clutch Adjustment
How do you adjust the clutch? Its a 90 7.3 non turbo 2wd......I know its a total newb question but ive never done it and im tired of stomping the clutch through the floor and prying up on the steering wheel just to get it to release and shift.....
Old Aug 19, 2009 | 06:19 PM
kslb7's Avatar
Have you tried bleeding the slave cylinder to see if you can improve pedal response?
Old Aug 20, 2009 | 12:53 PM
Sycostang67's Avatar
You might want to check and make sure your firewall isn't tearing or flexing. It's a common problem on these fords. Have someone push the clutch pedal in while you watch the clutch master from under the hood. Ford sells a plate to help reenforce the firewall for $10-$15. I am pretty sure your clutch is not adjustable. You could get a clutch master cylinder pushrod for an 1985 F-250, it was the only year an adjustable pushrod was used.
katman
5.9L CR Performance
Sep 10, 2015 03:34 AM
Turbo67
Jul 25, 2015 02:26 PM
klu408
Apr 26, 2015 07:52 PM
ford_man
Feb 21, 2015 10:59 AM
Wyocumins
Oct 19, 2014 09:34 PM
