hub replacement
Old Aug 7, 2009 | 01:56 AM
biged681985's Avatar
Default hub replacement
i got to put some u-joints in a 06 dodge in the morning, and was wondering how yall get the hub out of the steering knuckle. on mine i beat and beat till i finaly got it out. and had to replace one of the hubs. i deffinatly dont need to mess up the hub, so whats the best way to get them out?
anyone with any hints besides just beating the **** outa it?
Last edited by biged681985; Aug 7, 2009 at 01:56 AM. Reason: Automerged Doublepost
Old Aug 8, 2009 | 11:37 AM
JTProuhet's Avatar
I forget how i got mine out... i sprayed A LOT of lube and let it sit for a little while.. I am pretty sure i used a slide hammer.... when i put it back together i used ALOT of anti sieze so maybe next time it wont be so hard..
Old Aug 8, 2009 | 12:07 PM
TCdodge's Avatar
yeah I used a slide hammer and a air hammer on mine. and alot of PB.
Old Aug 8, 2009 | 12:14 PM
JTProuhet's Avatar
same here
Old Aug 8, 2009 | 05:13 PM
TCdodge's Avatar
ummmmm.......... hopefully it dont have to many miles on it so it comes apart fairly easy. the slide hammer dont tear it up though. a heat gun might help to.
Old Aug 9, 2009 | 06:37 PM
tinysdodge's Avatar
take the bolts out then screw one back in acouple of threads on the bottom back hole.
Then put a socket and a extendion to the lower control arm bracket and have someone start the engine and turn the wheel acts like a press while you beat on the knucle where the claiper goes. You mite have to do it to the front top bolt to. I tried a slide hammer to but i wrecked my bearings cause your hammering on the hub bearings not the housing
Old Aug 9, 2009 | 09:01 PM
thanks, i had a puller, but on my 99 i pulled the bearing apart with it, i think it was bad any how, but i put the puller on it and turned the wheel, tightened it up again, turned the wheel, till i had a 1/8 inch gap behind it, then used an air hammer to spilt it up more.
Old Aug 9, 2009 | 09:37 PM
dieseldude03's Avatar
I've always had to just pour the PB Blaster to it everyday for a week then beat the hell out of it with a BFH. Slide hammers and pullers seem to destroy the hubs more often than not.
Old Aug 14, 2009 | 12:25 PM
JTProuhet's Avatar
i never touched the bearings with the slide hammer... maybe i was hammering on a different part of the hub.. i cant remember where i had it... mine came apart fairly easy.. truck had 65k
Old Aug 14, 2009 | 01:09 PM
mysterync's Avatar
Snap on has a special socket to push it out with the stop.
