pump timing
Old Aug 6, 2009 | 08:02 PM
95cumminsguy's Avatar
Default pump timing
Im just getting ready to install my pump on my 95 im building and I wanted to ask you guys what would be the best timing for it. It will have #0 plate and 100 hp injectors to start with the head is ringed and studded. Also when you guys talk about advancing the timing a certain amount of degrees how do you determine what a degree is? is 1 degree equal to one tooth on the pump gear??
Old Aug 6, 2009 | 08:50 PM
bowtech's Avatar
i think evey click is like .5 a degree i was lookin on some pics and instructions and it was saying some thin like that
go to the search and type in timing
Old Aug 6, 2009 | 09:27 PM
hey thanks i found a post that says how to do it by searching, now I would still like to know what i should set it at maybe somebody can tell me thats done it where the best spot is then i should be on my way
Old Aug 6, 2009 | 09:51 PM
xzaq103's Avatar
FormerVendor
mm lift in the pump
Stock head no more than 17* on a studded and o-ringed head you can do a lot more (not sure how high) I would stay around 20-22 on the street.
Old Aug 6, 2009 | 10:16 PM
bowtech's Avatar
i have a stock head and going to have it set at 16 every one on here was saying that is safe
Old Aug 6, 2009 | 10:19 PM
hunter's Avatar
iv heard that 18* is the safest with no studs, but since uv studed the head i would say 20*
Old Aug 7, 2009 | 12:33 AM
94cummins12v's Avatar
i had mine at 18* when i rasnt runnign studs, now with the studs i would like to go to 20*
Old Aug 7, 2009 | 03:54 PM
94 12valve's Avatar
Originally Posted by xzaq103
mm lift in the pump
I'm at 22.5* with at studed and o ringed head but my injectors have a narrowed spray pattern and I'm running the .020 washers so I'm easly still in the bowl... I would stay arround the 17 - 18* range
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
letters4and18
Mar 25, 2015 03:06 PM
SMatyac
Nov 15, 2014 07:35 PM
