HOT ENGINE TEMPS
Old Aug 5, 2009 | 10:13 PM
DieselPerformanceGuy's Avatar
Default HOT ENGINE TEMPS
my engine runs hot all the time. it takes like 2mins while driving for it to get it heatedup.
i've been noticing that when i have to let the egt's cool down the engine gets hotter, and when i'm driving around town it seems to heat up.
this is all without the a/c when the a/c is on it's worse but just tonight my engine temps were almost on the H it was almost to the line before the h i mean.
should i try draining the coolant and putting some new coolent in.
Old Aug 5, 2009 | 10:20 PM
jasonfriedlin's Avatar
These first gens are known for being hot, hot egt's, hot coolant and oil temps. Nothin on them is big enough, the turbos, radiators, or intercoolers for those of you that have them. Check your radiator cap. Mine was bad and I kept losing a lil coolant but couldnt figure out where it was going. It wouldnt hold any pressure, got a new one and mine is runnin a lil cooler now. A good coolant system flush and new coolant certainly wouldnt hurt anything but check the cap too
ltr450's Avatar
you can try draining the coolant but it might not help unless it is clogged, might be bad water pump or you thermostat is suck or your radiator fins need a nice cleaning
Old Aug 5, 2009 | 10:26 PM
thanks i'll try those thing
couldn't hurt
would the water pump affect the a/c also cuz i have been noticing that my a/c doesn't really work the air is way hotter thean my other 12valves
Last edited by DieselPerformanceGuy; Aug 5, 2009 at 10:26 PM. Reason: Automerged Doublepost
Old Aug 5, 2009 | 10:27 PM
No the a/c may just need a shot of freon and the hotter it is outside the hotter the air the a/c is gonna blow
Old Aug 5, 2009 | 10:36 PM
yea i noticed that the littlest bit of temp outside makes a big difference on the a/c
how do u tell if ur water pump is going out.
Last edited by DieselPerformanceGuy; Aug 5, 2009 at 10:36 PM. Reason: Automerged Doublepost
Old Aug 5, 2009 | 10:46 PM
IDK it either works or it doesnt. Most of the time when they go out they leak or the bearing makes alot of noise. Never had that problem on my dodge but on other vehicles. Probably be harder to hear the noise on the diesel over a gasser
Old Aug 5, 2009 | 10:50 PM
ya idk i'll check if mines likin or makin noise but if it's not than i'll try to clean the radiator and put new fluid in
thanks for your help sir
Last edited by DieselPerformanceGuy; Aug 5, 2009 at 10:50 PM. Reason: Automerged Doublepost
Old Aug 5, 2009 | 10:52 PM
No problem, dont forget to get the new radiator cap too. Its only like 8 bucks or something
Old Aug 5, 2009 | 10:54 PM
ya i bout forgot but ya i bet that will help cuz the people that my dodge before me opened it when it was hot and shot a big hole in my hood.
looks like crap and the cap is kinda bent up but i dont think it leaks fluid but it might not hold pressure
