E4OD controller
Old Aug 5, 2009 | 04:46 PM
Suberbuggy's Avatar
Default E4OD controller
Does any one know if there is an upgraded/performance transmission controller for the E4OD in my '93 E350 7.3N/A? It seems to shift late sometimes, and kick down too early when climbing only a slight grade. Is the stock controller programmable? The trans has been replaced with a reman from Ford some time before I got the van. The van has 352K on it. Any other questions? Thank you for any help.-Cory
Old Aug 5, 2009 | 10:09 PM
stkdram55's Avatar
i doubt there is a controller but someone has to make or would make you a shift kit for it...it might just need a new valve body
Old Aug 18, 2009 | 09:59 PM
bigmike29's Avatar
Banks makes a controller I know it comes with the sidewinder kit and I pretty sure u can buy it seperate for unde 300 dollars
Old Aug 18, 2009 | 10:12 PM
mysterync's Avatar
I'm pretty sure that all the banks controller does is control lock up for an exhaust brake. I've driven a truck with one and didnt see much diffrence. The best fix for your problems is probably going to be a Valve body, You may also have some pre-existing transmission problems.
Jake9473
Jul 22, 2018 08:19 AM
F250MACH
Apr 26, 2015 05:19 PM
steed
Basement Enterprises
Apr 7, 2015 04:07 PM
1997silverado
Mar 12, 2015 11:11 PM
