AC Temp
Old Aug 5, 2009 | 11:15 AM
solarwarp's Avatar
Default AC Temp
Does your Air Conditioning keep up in 100 degree heat?
When I am moving, it isn't too bad... but when I am stopped the air blowing from the vents isn't as cold. Is this normal?
Old Aug 9, 2009 | 02:49 AM
JakeB's Avatar
Dunno if it's normal, but mine does the same thing. I live in Az and were over 100 degrees every friggin day!
Old Aug 11, 2009 | 03:14 PM
Grider Pirate's Avatar
My '99 was doing that for about a year, then it started overheating in 'round town' conditions. I live in Las Vegas, and 110 plus days are not unusual. Last week I pulled the radiator out and was absolutely astounded at how clogged the exterior was. From the back it looked fine, but the front had a circle of crud corresponding to the outline of the fan that was completely obstructed. Ten minutes with the pressure washer cleaned it up fine, and now the air blows ice cold even stopped in crappy Las Vegas traffic in 105 degree heat.
Pulling the radiator is easy, and all it will cost you is some anti-freeze.
Cheers,
Jim
Old Aug 14, 2009 | 10:22 AM
solarwarp's Avatar
Maybe I'll pop the hood and see if I need to clean out the butterfly splat from the radiators...
Old Aug 17, 2009 | 02:03 PM
The problem area is between the intercooler and the radiator. I attempted to clean mine without removing the radiator and had no luck at all. Hope you do better.
Old Aug 17, 2009 | 02:12 PM
mysterync's Avatar
The clogging issue is caused by the blow by bottle. THEY MUST BE RELOCATED.
If you can get some gauges on your truck, and a gauge in one of the vents I'll let you know if it's in spec!
Old Aug 18, 2009 | 01:08 AM
94cummins12v's Avatar
cut the water flow to the heater core and that will drop the temps considerably
Old Aug 18, 2009 | 10:04 AM
solarwarp's Avatar
What is the blow by bottle you are talking about?
I saw this on another forum, where they cut the lines and inserted valves... I would worry that would cause the coolant in the heater exchanger to get stagnant and maybe cause problems?
Old Aug 19, 2009 | 05:16 AM
LOGANSTANFORTH's Avatar
It was posted in this section of the forum by Wildcat......
casper83
23
Jul 27, 2015 01:53 PM
doodieroot
May 10, 2015 11:48 PM
99stackedpowerstroke
Feb 7, 2015 10:58 AM
emilio2496
8
Jan 13, 2015 05:03 PM
mule97
Dec 12, 2014 05:05 AM
