nitrous to propane???
Old Aug 5, 2009 | 09:28 AM
Saams69's Avatar
Default nitrous to propane???
Ok my friend has a brand new nitrous kit for a gasser that he wants to sell to me. My question is could i use all of that stuff and just make a propane tank hook to it. If so how much should i run im my truck its a 91.5 intercooled, maxed pump, shaved fuel pin, 366 spring, and a straight pipe. It also has a 175000 miles on it. Thanks in advance guys!!!
Old Aug 5, 2009 | 11:24 AM
jasonfriedlin's Avatar
I think you could just use the nitrous. RSWORDS is running it on his truck maybe he will have something when he gets home from work
Old Aug 5, 2009 | 01:21 PM
Saams69's Avatar
well i was kinda under the impression that propane is alot safer for the engine and easier to get. but thanks and im lookin forward to hearing what he has to say.
Old Aug 5, 2009 | 04:34 PM
peobryant's Avatar
What do you want to do with the truck? Why do you want to run nitrous?
Old Aug 5, 2009 | 04:59 PM
RSWORDS's Avatar
You mean run a propane bottle with propane in it through the nitrous solinoid and nozzle? No... You need a regulator for propane. Just hook up the nitrous system and enjoy! Propane regulators go bad and you have a HUGE exlosion under the hood. Propane causes higer EGT's, Some get slower spool up, you also have to worry about detonation and increased timing due to a fuel being drawn into the engine vs injected. That is HELL on a head gasket.
The 2nd and 3rd run were on Nitrous... you can hear/see the difference....
Old Aug 5, 2009 | 06:48 PM
Saams69's Avatar
well this system is a wet system could i use it at that or should i make it dry. Also how much should i run. 25hp 50hp shot?? Thanks guys i would like to know as much as i could also that truck is sweet huge difference with the nitrous.
Old Aug 5, 2009 | 07:45 PM
RSWORDS's Avatar
Dry. No need to inject fuel. All you will do is cause pre-detinantion and it wont atomize clean enough anyway. Start small and work up till you see the smoke clear up. If it starts popping back it down a little.
Old Aug 5, 2009 | 08:53 PM
Saams69's Avatar
ok that reminded me of one other question. if i try to rev my truck up it will start popping do i need another fuel pump i dont have a fuel pressure gauge nor do i know where to hook one up. Thanks alot for your help guys!!!!
Old Aug 6, 2009 | 03:48 PM
RSWORDS's Avatar
I would get a fuel pressure gauge in there. You can get a tapped banjo bolt that goes on the line from the pump to the filter housing.
Old Aug 6, 2009 | 08:39 PM
Saams69's Avatar
ok thanks you are my savior!!!! LOL
