egr
Old Aug 4, 2009 | 09:29 PM
churkeepwrstrke's Avatar
Default egr
is it possible to clean the egr vavle ive heard it is? is so how? mines went out 3 times.
Old Aug 5, 2009 | 07:21 AM
HeavyAssault's Avatar
Locate EGR valve on top of motor, disconnect plug, remove two mounting bolts. Try prying on the bolt holes after you turn the EGR valve this will help you get under the lip. Clean as needed, reinstall.
Old Aug 5, 2009 | 11:44 AM
CSIPSD's Avatar
Or just order up one of the many delete kits that are out there and forget about the biggest POS part ever put on a Diesel...
Old Aug 6, 2009 | 09:20 AM
Diesel Powered Rocket's Avatar
If you go this route, you will need custom tunes or you will have a check engine light on all the time. The valve is not hard to clean. I used to do it at every oil change.
syctaz
Jun 26, 2015 12:20 PM
kestmic1
Jun 8, 2015 12:44 PM
willyam
Price Quote - Request A Price
May 19, 2015 10:20 AM
Bighouse
Apr 9, 2015 06:51 PM
tbreddiesel
Thoroughbred Diesel
Jan 12, 2015 02:23 PM
