99 dodge codes? help please
Old Aug 4, 2009 | 07:38 PM
yj junker's Avatar
Default 99 dodge codes? help please
got a new scanner today and from the codes I am getting from it looks like I may need a vp44
here are the code what do you guys think?
active codes after I cleared them and started it again
P0251 Injection pump metering control a
P1688 Internal fuel injection pump failure
P0252 Injection pump fuel metering control a range/perfomance
first scan codes were the three above plus two others
P0237 Turbo sensor circuit low
P1689 no comm between ECM and Injection pump
Old Aug 4, 2009 | 07:48 PM
turbo20psi's Avatar
Codes of death for the VP44.Does the truck in ? run.Sorry man
Old Aug 4, 2009 | 07:52 PM
yj junker's Avatar
it will start but it will barely haul itself and is skipping and missing really bad
Old Aug 4, 2009 | 08:13 PM
turbo20psi's Avatar
yep vp44. sounds like the electronics are failing with the p1689 code.
Old Aug 5, 2009 | 11:28 AM
P1688 generally means a bad VP-44. You also might have a wastegate issue ??
Which scanner did you get?
Old Aug 5, 2009 | 04:39 PM
yj junker's Avatar
the same scanner as yours Dr. my buddy was working and 1/2 price it was
Dec 29, 2014 10:20 AM
Dec 12, 2014 12:30 PM
Nov 16, 2014 06:10 PM
Nov 3, 2014 08:10 AM
Oct 24, 2014 02:50 PM
