single stacks
Old Aug 2, 2009 | 07:26 PM
hunter's Avatar
Default single stacks
hay i have a set of grandrock 5 in. stacks installed and im wanting to make a single stack kit out of them without spending a lot of money is that possible.
Old Aug 2, 2009 | 07:52 PM
01trailerpuller's Avatar
It is possible. You will need a new pipe to replace the Y pipe. Check ebay or craigslist for someone going from a single to twins. Good luck.
Old Aug 2, 2009 | 08:05 PM
stkdram55's Avatar
well actually the pipe that goes thru the bed and hooks to the y-pipe, just take the y-pipe out and hook one of your stacks up the pipe that comes up thru bed....
Old Aug 2, 2009 | 08:08 PM
hunter's Avatar
the 90 degree pipe,is it 4 or 5 in
Old Aug 2, 2009 | 08:11 PM
stkdram55's Avatar
you tell us, but im pretty sure its 4 inches....thats usually what they use...is the y pipe smaller then the stacks or do the stacks reduce down to fit the y pipe
Old Aug 2, 2009 | 08:13 PM
hunter's Avatar
the stacks are 5 in. the dont reduce
Old Aug 2, 2009 | 08:20 PM
stkdram55's Avatar
so the y pipe is 5 inches then...but chances are the 90 is a 4 in and you will need a 4 to 5 inch adapter to hook it up
Old Aug 2, 2009 | 08:59 PM
hunter's Avatar
so i get a 4 to 5 and we should be in buissnes the huh
thanks buudy
Old Aug 2, 2009 | 10:43 PM
97cummins's Avatar
Old Aug 3, 2009 | 10:31 AM
Nitelord's Avatar
Good luck with your project.
Enjoy your stay..
lancegibbs51
5.9L 12V Performance
Aug 19, 2015 12:15 PM
tim12valve
May 29, 2015 05:19 AM
usaman
Oct 25, 2014 03:29 PM
tbreddiesel
Thoroughbred Diesel
Oct 14, 2014 07:44 AM
