Vibrating 04
Old Aug 1, 2009 | 05:42 PM
Cummins_47re's Avatar
Default Vibrating 04
My dad has a 2004 2500 4x4 quad cab short box 48re. Stock other than muffler and an s&b intake. Well soon as you hit the throttle it starts to vibrate. let off goes away. I checked u joints and the drive shaft...any ideas. It's pretty bad.
Thanks
Old Aug 1, 2009 | 11:41 PM
SD207434's Avatar
does the truck have any other symptoms? loss of power? tranny issues?
Old Aug 1, 2009 | 11:57 PM
skinnysfd's Avatar
Is the vibration from the front,back,middle?
Old Aug 1, 2009 | 11:58 PM
SD207434's Avatar
you could also check the torsion damper
Old Aug 10, 2009 | 11:59 AM
Ram04SLT's Avatar
Check the Driveshaft..
Had pretty close to the same issues your having, ended up being the rear U-joint on the drive shaft was half frozen
