gear vendors under/overdrive
Old Jul 31, 2009 | 04:46 PM
firstdiesel's Avatar
Default gear vendors under/overdrive
GEAR VENDORS under/overdrive unit. Is also in good shape only used for a couple of months. It came off of a 01 dodge ram 3500 4x4. (this unit will fit anything all you need is an adapter which you can get from gear vendors). It will also come with all the paper work. And it also has the shorter drive shaft that will come with it(for dodge)if you want it. I took this off because i dont go on long trips anymore.
I would like to get $1500 out of it thanks
Old Aug 1, 2009 | 01:27 PM
HotRodCrewCab's Avatar
Hi, my truck is pretty much identical to yours. Did this unit make a big difference with fuel economy?
Old Aug 1, 2009 | 04:35 PM
it would bring the crusing speed from 2200rpm to 1700rpm. it made a difference. you can only use the o/d when you are not towing.
if you want to call me them PM me and ill give you my phone number.
here are some pictures
Attached Thumbnails gear vendors under/overdrive-truck-stuff-004.jpg   gear vendors under/overdrive-truck-stuff-005.jpg
Old Aug 14, 2009 | 08:28 PM
sold thanks
corksil
Aug 2, 2015 10:19 PM
Jun 4, 2015 09:30 PM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:27 AM
rtbcoop
Nov 29, 2014 11:33 PM
Spiderman
Oct 6, 2014 09:52 AM
