"Service Engine Soon" light & fault code
Old Jul 31, 2009 | 12:37 PM
ArmyAviator's Avatar
Default "Service Engine Soon" light & fault code
Greetings all.
About a week ago, "Service Engine Soon" light comes on; @ my local service center (not a diesel shop), the fault code indicates "misfire on #4".
It was reset and remains so for about a week. Just reappeared.
Worrisome?
Solutions?
--Bryant
Old Jul 31, 2009 | 01:57 PM
wildbill's Avatar
Bad injector or a short in the wiring.
Old Aug 1, 2009 | 07:11 AM
Wild Bill, thank you.
I can fly the hair off of a $19million Army helicopter but I truly know very little about diesels, much less the Duramax. If you've time, I'd really appreciate your thoughts on my questions below:
Is this an issue that should be checked out by a GMC dealership service dept or should I look for a recommended non-dealership shop?
Why is there no other "noticeable" in how my truck runs?
As there is no noticeable difference to me, am I hurting the truck by running it?
If it is the injectors, do I change all of them? Just that one? Just one bank/side?
And....should the injectors be replaced with factory or do you recommend and "upgrade"?
--Bryant
Old Aug 1, 2009 | 12:32 PM
2500HeavyDuty's Avatar
first get the balance rates checked on the injectors and find out exactly what code it was so we can help you better.
could be a bad injector. the wire harness really doesn't get loose on the lb7's at all
Old Aug 1, 2009 | 12:48 PM
The code is P0304.
Old Aug 1, 2009 | 03:18 PM
ok, Do a balance rate test, find somebody with a tech II, efi live, or a programmer that can check that, injector #4 is whats setting the code off.
burndiesel
10
Feb 7, 2023 01:15 AM
Flash123
Ford Powerstroke 08-10 6.4L
Jun 25, 2015 10:19 PM
Higgy
Jun 5, 2015 09:16 AM
gauge1325
May 3, 2015 01:33 PM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
