Diesel Related Events Post All Diesel Related Event Information, Dates and Results Here - Includes Racing, Pulling, Dyno ect... All Local, State and National Event Information
*POST AND DISCUSS ALL DIESEL RELATED EVENTS HERE*
mid south delta fair truck pull
Old Jul 30, 2009 | 03:37 PM
need help 6.7's Avatar
Default mid south delta fair truck pull
Host:
Off in the woods pullin team and the Delta Fair
Type:
Other - Festival
Network:
Global
Date:
Monday, September 7, 2009
Time:
1:00pm - 11:00pm
Memphis Agricenter International
Street:
7777 Walnut Grove Rd.
Phone:
9012994682
Description
Delta Fair Truck Pull- Labor Day- September 7, 2009
7777 Walnut Grove Rd. Memphis, TN 38120.
· Registration starts at 1p.m. Pull starts at 2 p.m.
· 75% payback and a $30 entry fee
Truck Pull Classes
Gas Class- Street legal gas truck. Anything goes but must be street legal.
Stock Diesel Class- Stock Turbo, Aftermarket Intake, Exhaust and Programming allowed, no visible performance modifications other than intake and exhaust. Maximum Weight 8500 lbs
Diesel Class 2- Stock turbo, Fuel system modifications allowed, hanging weights allowed, Max weight 8500 lbs
Diesel Class 3- Aftermarket Turbos, hanging weights allowed, maximum weight 9000lbs
Diesel Class 4- Anything goes, nitrous, propane, water methanol, no weight limit
Rules
·First Puller in each class gets the option to re-pull
·1” Suspension travel in all classes except Diesel 4
·If you break a drive shaft and you don’t have u-joint shields your pull is disqualified. If you break a drive shaft and you have shields your pull counts.
·If your hitch breaks you are disqualified
·If you are unable to drive the truck off the track you are disqualified
·If you have not reached 75ft. you may back up and start over one time.
·All tires must be DOT legal uncut
·Exhaust must exit behind the cab in all classes except Diesel 4
·The three members of the tech staff will address anything the tech staff finds unsafe or unfair. Three tech staff members will be present on each tech inspection.
·Nitrous, Propane, Water-methanol allowed only in Diesel class 4
·If a truck is over 8500 lbs. in the stock diesel class the tech staff has the option to let them pull if no weight has been added. Don’t show up with a full tank of diesel and be over 8500 and expect to pull
For questions about classes or rules call Justin Hoback 901-299-4682
__________________
Pulling promotions
Sep 18, 2015 01:39 PM
JSATCT860
Towing and Hauling
Jun 15, 2015 11:21 PM
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Oct 14, 2014 08:40 AM
