steering box
Old Jul 29, 2009 | 06:41 PM
smokedout's Avatar
Default steering box
My truck has about 4 inchs of play in it both ways and when I let go it pulls to the right hard. What do I need to do or replace in order to stay on the road in the morning, its hard enough to stay awake!
Old Jul 29, 2009 | 08:03 PM
Racer9's Avatar
You need to climb under it and have someone rock the steering wheel back and forth, while you look for whatever's loose. Could be steering box, any of the steering linkage, ball joints, wheel bearings, or track bar. Don't just start throwing parts at it, fix the ones that are bad.
Old Jul 29, 2009 | 08:51 PM
Johnny Z's Avatar
Welcome to Dodge Steering
Old Jul 29, 2009 | 09:10 PM
Uncle Bubba's Avatar
Along with all this make sure that track bar has your truck centered right. If it is a constant pull to one side chances are that track bar isn't centered.
Old Jul 30, 2009 | 12:53 AM
94cummins12v's Avatar
i have the same amount of play in mine 50% is from the slop in the stearing shaft ant the other 50% is from the gear box. im going to build my own steering shaft this winter to eliminate the play
Old Jul 30, 2009 | 01:59 AM
I converted to the Borgenson steering shaft and in my case it made no difference but the new steering gear was like night an day difference.
Have a look through this thread. It covers about everything there is to the front end of your truck. https://www.dieselbombers.com/5-9l-2...d-rebuild.html
Old Jul 30, 2009 | 09:56 AM
LOGANSTANFORTH's Avatar
i had the steering come apart on me one day.......i was only doing 10 mph at the time thank god......the tie rod at the steering box came loose from the passenger side tie rod.....
Old Jul 30, 2009 | 07:18 PM
smokedout's Avatar
Default FUEL FILTER OFF
i CANT GET THE DAMN THING OFF! ANY IDEAS?
Old Jul 30, 2009 | 11:13 PM
Which thing you talkin about here.
Antwhite19
Aug 23, 2015 06:07 AM
Boostaddiction
May 4, 2015 06:28 AM
BubbaDT55
Apr 12, 2015 10:47 PM
Rusted Dragon
Feb 27, 2015 09:46 PM
sweetv8s10
Oct 7, 2014 09:47 PM
