water in passenger floor board
guys i have water leaking in my passenger floor board from somewhere.usually that means heater core,but this is pure water,no anti-freeze,and no foggy windows.it's also not the windshield,it does it rain or shine.
I would put my finger on it that it is the drain for the a/c evaporator is plugged up. The company I used to work for had a bunch of Nissan pickups and this would happen every summer. Dirt gets into the drain from the outside and plugs the hose. Crawl under the truck and look for a small rubber elbow or something protruding from the firewall. That is most likely going to be it.
mine was leaking when it rained... then it would stay in the cab because the padding would be soaked.. i took every piece of the interior out and sprayed water all around the cab and it was leaking in through the third break light, and running around the back glass and dripping behind the panel that covers the rear seat belt.. so it was wet even when it was beautiful out. . . sorry if you've checked that already, but it appears to be a fairly common problem...
oh yeah, and i sucked the water out several times with a vacuum before i actually found the leak... anyways, good luck!
