over heating 6.0
Old Jul 28, 2009 | 01:35 PM
ltr450's Avatar
Default over heating 6.0
why does this thing over heat evertime you pull with it. it has 4 inch trubo back exhaust and cai.
any one
Old Aug 1, 2009 | 07:47 PM
Big Angry Hillbilly's Avatar
Thanks for all the info that might help with diagnosis!
Blowing coolant out the degas bottle? Is the coolant low?
Tuner?
Check engine light?
Does the cooling fan work?
Etc...etc....etc....
Old Aug 1, 2009 | 10:40 PM
ltr450's Avatar
the truck works fine driving normal, coolant level is fine, no chip in this truck, fan works, and there are no codes. it just seems like every time he goes up a hill it just over heats realy fast pulling a 25ft goose neck with a skid steer or a tractor on it.
Old Aug 1, 2009 | 10:49 PM
DB Admin's Avatar
Banned
everyone i know that has a 6.0 has had to replace the turbo under warentee not sure if thats whats causing the over heating may want to get it checked out
Old Aug 1, 2009 | 10:50 PM
ltr450's Avatar
ok thanks
Old Aug 2, 2009 | 05:02 AM
HeavyAssault's Avatar
Does the overheating occur only when you tow?
Old Aug 2, 2009 | 10:51 AM
ltr450's Avatar
yes only when towing
Old Aug 3, 2009 | 09:49 PM
Pull the little cover off from the grille to the top of the rad support, and make sure between the radiator and charge air cooler isn't all filled with **** (dirt, fur, etc. etc.) That happens a LOT.
And I would get the fan checked at the dealer, I have seen this a lot with restricted air flow, malfunctioning fans, bad rad caps, *gulp* head gaskets, etc.
Still got warranty?
PM me the VIN
Old Aug 3, 2009 | 10:19 PM
ltr450's Avatar
i think the warranty ran out don't know vin number not my truck. i think the truck is a lemon. look at the carfaxs it had two owners before him they both only put 20,000 miles on it and traded it now he has it and it overheats gets 14mpg and has a small oil leak. he is look at buying a 07 ram3500. i know some people never have any problems with the 6.0 and some have every thing go wrong with them.
Old Aug 8, 2009 | 10:52 PM
Mainly directly related to misuse/abuse/lack of maintenance.
98% of failures on the 6.0 are related to what I just said.
slowstroke
For Sale
Apr 1, 2015 11:35 AM
scubasteve12
Mar 29, 2015 09:39 PM
MFARRENS
Jan 27, 2015 07:35 PM
thumperf350
Jan 8, 2015 12:55 AM
GWest
Oct 12, 2014 09:22 PM
