Valve Spring Retainers
Old Jul 28, 2009 | 11:06 AM
rkadcock's Avatar
N.M. Bombers Director
Default Valve Spring Retainers
What can the stock valve springs handle in terms of power and RPMs. I'm starting to beef up my engine internals and before I pull the valve springs to install billet retainers and keepers I would like to know if its necessary?
Old Jul 28, 2009 | 12:33 PM
12valvetater's Avatar
stock valve springs cant handle over 3200 or the valves start floating and bad things happen i didnt put billet retainers and keepers in mine when i built my engine not real sure when you need them
Old Jul 29, 2009 | 12:52 AM
94cummins12v's Avatar
on a street driven trcu the billet reatainers are way overkill, i would use them till i exceede 5k with the truck
Old Jul 29, 2009 | 09:10 AM
rkadcock's Avatar
I was thinkin they were a little over kill especially right now... But better safe than sorry
Old Jul 29, 2009 | 09:35 AM
Hammer's Avatar
Stock valve springs will be good enough for the occasional bursts over 3000.You will want to do something with the valve springs if you planning on life over 4000.Better retainers and keepers are a good addition to the truck seeing 4000 on a regular basis.However,if your planning on life over 4000 in competition then you may want to think about different valves and having the head cut for a much better valve spring to limit valve float and aid in engine life.Might even want to consider an aftermarket pushrod also if your leaning to running rpms that are in high orbit.
Old Jul 29, 2009 | 09:44 AM
rkadcock's Avatar
My plan is to rebuild the engine here pretty soon. Upgrade all the internals like pushrods, to billet, new coated pistons, have the head bored and o ringed, changing my main studs to 14mm, 14mm IP and so forth... Basically I'm looking at making my 97 a complete competition truck and using my 07 as my DD. As of right now I'm trying to get it all priced out so I only have to do it once.
51Hudson
55
Jul 8, 2018 08:17 AM
RA113024
Mar 13, 2016 07:42 PM
markv8993
Jun 21, 2015 12:24 AM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
