HX 50 EGTS
Old Jul 27, 2009 | 08:57 PM
jody langton's Avatar
Default HX 50 EGTS
Hey guys im new on the forum, ive got a 97 5.9 auto with lots of fueling, blew the poor little hx 35 not long after making 500/1000 at the wheels so i just built a custom hx 50 with a 1.0 exhaust housing to reduce the lag but no gate on it, my egts are like 1500 pre charger with 3 stages of water.... why....mabe my drive pressures are to high?? i have to check them, any info would be appreciated.
Old Jul 27, 2009 | 11:28 PM
mysterync's Avatar
You dont have enough fuel to spool the charger I'm guessing. If you could let us know what your other mods are. What wheels are in the charger? what compressor housing?
The hx-50 isnt really an efficent setup in the first place, It's a (pardon my french) Lag Wh*re. It's not setup to cool a heavily fueled truck. I'll drop a note to John P. and get his opinion, he's far more experienced in the 12v area!
Old Jul 28, 2009 | 12:18 AM
94cummins12v's Avatar
thats a big *** turbo to be pushing as a single. your lagging it way to much to be a streetable turbo without twins.
Old Jul 28, 2009 | 12:59 AM
You made 500hp on a stock HX35?
Old Jul 28, 2009 | 09:57 AM
id like to see the sheets on that one
Old Jul 28, 2009 | 10:16 AM
mysterync's Avatar
....I'm not saying anything, I'm just here to help
Old Jul 28, 2009 | 11:03 AM
No worries it is a custom 50 with stock wheels in it, i have tons of fuel, the turbo lights at about 600f pre charger and sails to 50 psi, the charger flows about 1200 cfm and still cant see the road for smoke, is it possible that it is still to small of housing it is a 1.0 exhaust witch is about a 14cm housing.
Old Jul 28, 2009 | 12:01 PM
mysterync's Avatar
It could be two small of a housing or you could be getting way to much fuel for that charger. Have you got a friend or someone close that might have a 66 you could try and see what results that nets?
Old Jul 28, 2009 | 04:55 PM
94 12valve's Avatar
so your saying your makeing 50 psi and 1200 cfm with 3 stages of water and your still over 1500*? and your fueling mods would be ... ?
Old Jul 28, 2009 | 05:24 PM
12valvetater's Avatar
thats a lot of fuel
