Is this normal????
Old Jul 27, 2009 | 07:28 PM
ron86toy's Avatar
Default Is this normal????
I thought I would be getting MPG's towing...I run east to west coast so I have had plenty of tanks to compare........I have towed my 26 ft enclosed trailer...now have a 28 ft bumper pull TT hooked to the truck.....and I cant get better than 11.5(hand calc).....truck is an '03 6sp 2wd 4.10.....I have smarty jr.(on tow tune)5' exhaust and s&b intake and stock airbox(saving for an icebox)....my enclosed I get the same with it loaded or empty(though I would have gotton better with the TT since my enclosed is extra height).....egt's been staying around 900 crusing 68(1200-1250 on the climbs) and boost is about 9-12lbs and will not go above 24lbs(no complaints about not having power).I have tried everything from 62-72 mph to cruise on/off and still the same....any help/suggestions...btw I get 21-22 empty at 68mph....I recently switched over from an OBS 7.3
Thanks Guys!!!!...back on the road..check back in a bit
Old Jul 27, 2009 | 08:43 PM
dustys24valve's Avatar
what's the weight of the tt compaired to the enclosed? My buddy had a tt that weighed about 11,ooo w/out packing it full to go camping. Depending on what you pull in your enclosed it all makes a diffrence.
Old Jul 27, 2009 | 10:08 PM
ron86toy's Avatar
TT is 6000lbs....my enclosed is 4k.....loaded with my rockcrawler,2 quads,tools,spare parts close to 10k....I get 11.5 all around....head/tail wind....mountains or plains....for a reference...my buddies '05(or '06????) on veggie is getting 14.5 pulling this around(he has a 6sp 3.73 with just a chip)...not sure of the total wieght...but I know its heavier than mine
Old Jul 27, 2009 | 10:09 PM
94cummins12v's Avatar
i like the trailer
Old Jul 27, 2009 | 10:16 PM
ron86toy's Avatar
Originally Posted by 94cummins12v
i like the trailer
.yeah...its pretty nice...he built it right....did not just pull the axles and throw it on a GN......extended the frame....lots of reinforcing.I think he needs to move the axles forward a bit....he has 4500 pin weight with the cruiser on the back.He says it pulls great like that though...its 41ft from the pin to the tail.
Old Jul 27, 2009 | 11:04 PM
emp1134's Avatar
5th wheels get better mileage than bumper pulls, used to pull them for a living, I could have a 40ft 13k lbs. 5th wheel and get 10-12mpg going 65-70mph, once I pulled a super light 4k lbs 23 ft TT and managed 8-10mpg with going the same 65-70mph. I would almost always get 2-3mpg better with a 5th wheel.
Old Jul 28, 2009 | 09:15 PM
skinnysfd's Avatar
I don't know much about these trucks kinda new to it but i pull a 24' enclosed trailer that weighs around 9500 with my stuff in it and i get 14 (hand calculated) and when i hook on to my 30' gooseneck with my 17,000 lb telehandler i get about 11. My boost with the telehandler will stay around 15 or so and with the enclosed it will stay around 9-13 but if i get on it hard it will go to about 32-35 and i just got a new turbo put in. I also took off my banks kit( selling if anyone is interested though) so all i have now is 4" turbo back exhaust other than that i'm stock. Mine is a 05 6 speed manual.
Old Jul 29, 2009 | 09:32 AM
GRI's Avatar
GRI
what is the smarty set at? default torque management setting and the no smoke timing setting will be the best mileage.
the standard trannys will get a little better mileage as well. your gear ration is a factor as well.
do you have a muffler on your exhaust set up? i gained 1mpg by adding a muffler to my straight pipe exhaust.
the rpms need to be 2k or less.
with what you are towing 11.5 isnt that bad.
Old Jul 30, 2009 | 06:14 PM
1badcummins's Avatar
that trailer is crazy i like it
corksil
Jun 30, 2015 06:58 AM
GHETTO_PIZZA
Mar 29, 2015 09:44 PM
misstiffany
Mar 21, 2015 09:43 AM
UniqueCopy
Dec 14, 2014 11:37 AM
Floydfan38
23
Nov 2, 2014 03:42 PM
