cruise control
Old Jul 26, 2009 | 02:43 PM
redneckcummins85's Avatar
Default cruise control
does anyone have an idea why my cruise control doesnt work? ive checked the fuse and the briefly checked the wiring but cant figure it out.... anyone able to shed some light on this problem?
Old Jul 26, 2009 | 03:30 PM
01quadcab's Avatar
had any front end work done? clock spring might be out
Old Jul 26, 2009 | 03:32 PM
slickbrave's Avatar
The easiest thing to check besides the fuse is the brake light switch. Make sure your brake lights aren't on when your foot's not on the pedal. If they are, that switch will keep your cruise from engaging.
Old Jul 26, 2009 | 03:47 PM
01 quadcab....havent had any brake work done , and slickbrave...the brake lights go off when i let off the pedal...but i appreciate y'alls input...if theres anymore suggestions...im all ears... i just did a 2000 mile road trip without cruise and it sucked! will be making another trip in 2 weeks and would love to have it! thanks
Old Jul 26, 2009 | 04:13 PM
slickbrave's Avatar
sounds like a trip to the stealership. On GM's the multiswitch went out often, but on the Dodge, it could get down to the module. It may be worth paying them for a diagnosis to rule out anything easy, and if you have to, here's one on ebay: http://cgi.ebay.com/ebaymotors/2002-...%3A1|72%3A1171
Old Jul 26, 2009 | 06:56 PM
Captn_tyler's Avatar
where is the fuse, mine doesnt work either, and I know the truck had front end work, what are clock springs. Wont even turn one so the crusie light is on
Redneck...check the vac lines, thats what I have been told in the past.
Old Jul 26, 2009 | 07:21 PM
Dirty Jersey CTD's Avatar
Check under driver side battery for broken vacuum line. Seem to be the spot to check. that can affect the vent doors in the climate system too. Thats where I found my problem at under battery.
Good luck,
John
Old Jul 27, 2009 | 03:26 PM
Mr.Krabs's Avatar
02's are electronic cruise.
My 01 don't work either,but that's cause I've got a 2000 engine in it,thought about changing the wiring all around...I just do without,since I ain't sure it will work...
Old Jul 27, 2009 | 10:00 PM
01trailerpuller's Avatar
Will it turn on or is it not engaging? If it is not turning on it could be the switch. I have a short in my steering wheel column, it will not turn on all the time, try taking the steering wheel and adjusting it up and down. Then see if it will turn on.
burndiesel
10
Feb 7, 2023 01:15 AM
JBearSVT
Jul 9, 2015 06:16 PM
jdnetx
Jul 2, 2015 07:38 AM
Oil Igniter
Nov 27, 2014 05:56 PM
Cliffordthe24v
Nov 6, 2014 12:19 PM
