coated pistons
Old Jul 25, 2009 | 05:11 PM
nick b's Avatar
Default coated pistons
i am thinking about building a new motor my 53 block took a dump on me what are coated pistons and the advantages of them is it worth doing
Old Jul 25, 2009 | 06:51 PM
94cummins12v's Avatar
theywill make it so your pistons can take more heat from the fuel you add. i had mine ceramic coated when i bought them. they are mahle pistons that i had to send somewere in california to have them coated. they told me they will withstand 1800* all day long since aluminum melts at about 1300*
Old Jul 25, 2009 | 07:32 PM
Begle1's Avatar
Think that they might have exaggerated a little bit?
Old Jul 25, 2009 | 07:48 PM
might have but i dont get my truck past 1200 at any given point, it was just an assurance knowing they can withstand the higher heat if i accidentally do it
Old Jul 25, 2009 | 09:00 PM
nick b's Avatar
hmm i can get to 1600 right now i think i will look into this so they have aluminum pistons i figured they would be steel
Old Jul 25, 2009 | 10:49 PM
nope aluminum expands and contracts at a much better rate. there full aluminum pistons, i had mine ceramic coated for $150 for the set ill look threw my recipts to find out who did the work
Old Jul 26, 2009 | 10:49 AM
Begle1's Avatar
Weight is also a big issue. Cummins currently uses articulated two-piece pistons with steel crowns and aluminum skirts on ISL's and ISM's, while the ISX uses all-steel pistons. Only the B's and C's are still stuck with aluminum.
The aluminum pistons are a limiting factor of our engines, almost as severe as our crappy heads. There are several sets of all-steel 24 valve pistons out there, which cost three-plus times as much as the aluminum pistons but let you raise your max-safe EGT threshold by 50%...
As far as coatings for aluminum pistons, the name I keep hearing through the grapevine is "PPE".
Old Jul 26, 2009 | 02:13 PM
AHolt's Avatar
Here is another place.
Performance coatings by Polydyn
4doorIDIot
6.9L & 7.3L Performance
Aug 1, 2015 06:02 PM
markanthonyhudson
Apr 18, 2015 04:17 PM
Kbnecessary
Mar 5, 2015 05:37 PM
