death wobble
Old Jul 24, 2009 | 02:07 PM
bowtech's Avatar
Default death wobble
i hit a cattle guard yesterday and got it and had to slow down alot to stop it what makes that happend and how i fix it?
Old Jul 24, 2009 | 04:45 PM
zjohnsonua's Avatar
Mine started this once the steering stabilizer went bad. Pretty cheap/easy fix for a scary problem.
Old Jul 24, 2009 | 04:49 PM
bowtech's Avatar
so just by a new one?
Old Jul 24, 2009 | 07:34 PM
96blackcloud's Avatar
i went through alot with mine man started after the 3in lift, put a new track bar bushing in got a little better, went through retightened everything got a bit tighter, did my alinment, put the caster maxed out positive and pushed the toe out to straighten em up. really helped alot. does it every once in awhile when i hit a big bump doin like eighty, but since then i got new tires, and all is good. also i replaced the swaybar endlinks, and dual steering stabs will be next.
Old Jul 24, 2009 | 08:22 PM
bowtech's Avatar
so check all the bars and stuff in the front end?
Old Jul 24, 2009 | 11:30 PM
94cummins12v's Avatar
check everything that your front end is made up of for play, mine was the track bar
Old Jul 24, 2009 | 11:36 PM
bowtech's Avatar
ok i had to ask you some thin brandon but i forgot
Old Jul 24, 2009 | 11:57 PM
DID YOU END UP GETTIN THAT TAP YET? if you need to call me tomarrow my number is 2086512377
Old Jul 25, 2009 | 08:56 PM
bowtech's Avatar
not yet. it was some thin else idk
Old Jul 25, 2009 | 10:46 PM
well damn i sent it 3 weeks ago, good thing there cheep
tbirdz24v
Aug 22, 2015 06:41 AM
SMatyac
Nov 11, 2014 12:49 PM
