Rear dana need help
Old Jul 23, 2009 | 11:15 PM
sawmillman's Avatar
Default Rear dana need help
About 6 months ago I had a rear wheel bearing go out (outer only) scratched up the axle tube I cleaned it up and replaced the bearing.Well every couple of months I'm tearing down axle to put a new axle bearing in.Also the last tear down the back of the outer bearing was completely gone eaten away and the seal was wasted.Tearing this thing down every other month is getting old and expensive
Old Jul 24, 2009 | 12:55 AM
94cummins12v's Avatar
something is out of alignment to be doing that
Old Jul 24, 2009 | 12:56 PM
davo79's Avatar
What are you torquing everything down to and is the axle a 70 or an 80 it should be 120 to 140 ftlbs on the axel shaft nut
Old Jul 25, 2009 | 04:18 PM
sawmillman's Avatar
It's a dana 80.The last tear down the back of the outer bearing was eaten away,I had to clean the tube surface to get the bearing on.BTW does anyone know the speedi sleve part numbers for the dana 80 (outer bearing and seal surface).Thanks
shingi
Off Roading
Sep 30, 2015 11:17 AM
Machinist
Jun 23, 2015 06:57 AM
woodsman27
May 23, 2015 10:16 AM
scrnnmssuck
For Sale
Mar 20, 2015 11:55 AM
gyayo2012
Nov 15, 2014 08:11 PM
