valve springs
Old Jul 23, 2009 | 08:48 PM
dan33klein's Avatar
Default valve springs
ok guys i feel stupid i cant figure out these valve springs.
i compress them and it says to strike the compressor lightly to free the keepers from the rotocoil?
thats the rotocoil?
any help asap
Old Jul 23, 2009 | 08:56 PM
davo79's Avatar
Compress the spring tap the top of the compressor and the 2 halves of the keeper will pop free then pick them out with a magnet and pull the spring and spring retainer off and walla you've removed the valve spring
Old Jul 23, 2009 | 09:09 PM
dan33klein's Avatar
kk
ill try that real fast
i just tried that.
i compressed the spring and gave the top of the compressor a few pretty good wacks and nothing happened.
the spring/valvestem/retainer can feely move up and down all together about a 1/4 inch
Last edited by dan33klein; Jul 23, 2009 at 09:09 PM. Reason: Automerged Doublepost
Old Jul 25, 2009 | 08:07 AM
daveO's Avatar
The keepers are split and they shouldn't move up and down with the spring, neither should the valvestem. The idea is to push the spring down without the valvestem moving at all. If you're doing this in the truck, make sure that your piston is at the right position, it sounds like maybe the valve is just falling into the cylinder. This could be a huge problem if you manage to get it apart as the valve will fall into the cylinder. If you're doing this with the head off the truck, make sure you hold the valve from the bottom so it doesn't move down.
Old Jul 25, 2009 | 07:51 PM
94cummins12v's Avatar
did you figure it out? i cant figure out what you mean in your pm about read your last post
RA113024
Mar 13, 2016 07:42 PM
Jake12valve
May 10, 2015 11:57 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
POWERSTROKEMANIAC
Dec 30, 2014 11:32 AM
